LAN IP
Guys,
Quick question here.
Say i have 3 MT.
MT A with WAN IP = 192.168.1.2
MT B with WAN IP = 192.168.1.3
MT C with WAN IP = 192.168.1.4
Question : Can i set the same LAN IP (say 10.10.100.1) for all the 3 MT as well as the ip pool (10.10.100.20-10.10.100.250)? Would it be affect WAN network (192.168.1.xx)?
if you set up masquarade then there will not be any problems.
but you can create VRRP configuration and on master set up that configuration changes on one of routers.
