Hi!
I am kinda new to Mikrotik and learning from the online tutorials. I got however to the point, where an issue does not make much sense to me, so I came for help.
I got the hAp ac routerboard. I got it as an replacement of the default ISP router, because I want to have a public-facing server running on my home network. I am using the default configuration, but:
- I disabled Wi-Fi and got Tenda cube access points plugged into ether3, set to bridge mode, so I can Port Isolate also the WiFi devices.
- I tried setting up the Port Isolation to isolate individual LAN ports, where server will be connected to ether4 (I want to separate it from other devices, because if it gets pwned by any chance, I do not want to have other devices exploited) Since the Port Isolation setup I can not ping devices on the other ports, so I guess it worked. Even Tenda app showed only devices connected to the WiFi and the router, not my PC wired to the Mikrotik on ether2.
- Disabled every service except the WinBox to access the router.
- I set servers internal IP to static,
- After this was done, I started looking at the Port Forwarding. I set up the rules.
- When I wanted to try it, I couldn’t connect from my other devices on the network, I learned that I needed to setup Hairpin NAT, so I did that based on the Mikrotik tutorial.
YAY! I could connect from outside and the inside!
However, then the issues came.
- After I finished config on my Windows PC, I started the server, tested the server with friend, both could access it.
- Then I turned off the Windows PC. After returning a few hours later, the LAN stopped working. I could access any website. When trying another Windows device, it did not work there either.
- What is surprising is that the WiFi works on any device. And the Ubuntu Server connected to ether4 seems to be able to ping google.com after a while after booting.
- What is also worrying that I started seeing the Ubuntu Server device and also my Windows PC when connected via wire in the ether2 and ether4 (Port Isolation should prevent this, no? Tenda app did not use to show them until I did the steps 4-6 [Not sure which one may be faulty])
- I was running only points 1, 2 for a longer while, back then there were no issues.
So, my questions are:
- How to fix this? What is the issue here? (From my POV I just applied default settings, did non-invasive changes and did port-forwarding; I ran out of ideas what may be wrong here)
- Is Port Isolation reliable for my use-case? (Separating my other devices from the public facing server, to protect them in case of server exploit)
- How is it possible that after doing the port-fowarding stuff and hairpin NAT I can suddently see also the Wired Devices that should be isolated?
I am attaching also my config export. I replaced my Public IP with a string “PUBLIC-IP”.
Do you know by any chance what may be wrong? Do you have any additional recommendations?
Thanks in advance.
# 2024-08-12 19:01:54 by RouterOS 7.15.3
# software id = -
# model = RB962UiGS-5HacT2HnT
# serial number = -
add admin-mac=48:A9:8A:F1:D1:CF auto-mac=no comment=defconf name=bridge
/interface ethernet switch port-isolation
set 1 forwarding-override=ether1
set 2 forwarding-override=ether1
set 3 forwarding-override=ether1
set 4 forwarding-override=ether1
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf disabled=yes interface=sfp1
192.168.88.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.88.51 client-id=\
ff:1:22:10:38:0:2:0:0:ab:11:6f:a9:8:49:72:df:70:e1 mac-address=\
08:BF:B8:71:3E:B8 server=defconf
192.168.88.1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=dst-nat chain=dstnat comment=Minecraft dst-address=PUBLIC-IP \
dst-port=33333 protocol=tcp to-addresses=192.168.88.51 to-ports=25565
add action=dst-nat chain=dstnat comment=SSH dst-address=PUBLIC-IP \
dst-port=717 protocol=tcp to-addresses=192.168.88.51 to-ports=22
add action=masquerade chain=srcnat dst-address=192.168.88.51 out-interface=\
bridge protocol=tcp src-address=192.168.88.0/24
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Bratislava
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
EDIT: The LAN randomly came back up on my Windows PC device, it happens rarely and I have no idea what is the cause.
EDIT2: After the router restart the described issues are back ofc.
EDIT3: LAN came back for 10 minutes and went back down. It is pretty random. The moment it breaks, the Tenda app starts showing the Wired connections that should be Port Isolated. When LAN works properly, the devices on the Port Isolated ports do not seem to be visible.
