LAN to LAN VPN Disconnecting
I just want to start off by saying my knowledge of a Mikrotik is very limited.
We have a scenario where we have a LAN to LAN VPN, Mikrotik one side, WatchGuard the other however recently it has intermittently disconnecting. The log shows the following.
phase1 negotiation failed due to time up local-end-ip[500]<=>remote-end-ip[500]
Usually it will usually reconnect, eventually, but occasionally we have to reboot the Mikrotik. We need this tunnel to be as constant and stable as possible. There are several VPNs of a similar nature going to the WatchGuard though usually Drayteks which are all stable, so I believe the problem to be somewhere on the Mikrotik. The two internet connections themselves do not lose any packets when the tunnel drops.
Firewall filter rules
 0    ;;; Accept ICMP
      chain=input action=accept protocol=icmp log=no log-prefix=""
 1 XI  chain=input action=accept protocol=tcp dst-port=7746 log=no
      log-prefix=""
 2    chain=output action=reject reject-with=icmp-network-unreachable
      protocol=tcp dst-address=redactedwanip log=no log-prefix=""
 3    chain=output action=reject reject-with=icmp-network-unreachable
 4 XI  chain=input action=accept protocol=tcp dst-port=7746 log=no
      log-prefix=""
 5 XI  chain=input action=accept protocol=tcp dst-port=7746 log=no
      log-prefix=""
 6    ;;; Accept established related
      chain=input action=accept connection-state=established,related
 7    ;;; Accept Established Related
      chain=forward action=accept connection-state=established,related
 8    ;;; Accept remote access
      src-address-list=RemoteAccess in-interface=ether1
      dst-port=88,8022,8443,8291 log=no log-prefix=""
 9    chain=input action=accept protocol=udp src-port=500 log=no
      log-prefix=""
10    chain=input action=accept protocol=ipsec-esp log=no log-prefix=""
11    chain=input action=accept protocol=ipsec-ah log=no log-prefix=""
12    ;;; Allow Remote Server Access to 192.168.51.0/24 Network
      chain=forward action=accept src-address=10.0.1.20
      dst-address=192.168.51.0/24 log=no log-prefix=""
13    ;;; Allow Remote Server Access to 172.16.32.0/20 Network
      dst-address=172.16.32.0/20 log=no log-prefix=""
14    ;;; Allow Remote Server Access to 172.16.32.0/20 Network
      dst-address=192.168.37.0/24 log=no log-prefix=""
15    ;;; Drop all other input
      chain=input action=drop in-interface=ether1 log=no log-prefix=""
16    ;;; Drop invalid
      chain=forward action=drop connection-state=invalid log=no
      log-prefix=""
17    ;;; Drop All Forwarding Un-wanted
      chain=forward action=drop in-interface=ether1 log=no log-prefix=""
NAT rules
 0    chain=srcnat action=accept src-address=172.16.32.0/20
      dst-address=10.0.1.20 log=no log-prefix=""
 1    chain=srcnat action=accept src-address=192.168.51.0/24
 2    chain=srcnat action=accept src-address=192.168.37.0/24
 3    ;;; Masquerade NAT
      chain=srcnat action=masquerade out-interface=ether1 log=no
      log-prefix=""
Any ideas are welcomed. I find it puzzling as there have been no configuration changes on either end yet this was working perfectly until 2 days ago.
