I setup a diskless server(pxe server). All clients and server is connected directly to a dumb switch at same subnet. Mikrotik handles the dhcp/gateway. Now, I want to route LAN traffic from client to switch to server directly. The problem is that the traffic from PC01 → Dumb switch → to Mikrotik ether2 interface then on my bridge then out to eth2 → switch again then to → Server.
Maybe the traffic is passing to cpu since I see cpu spiking to 25%. Also I see traffic going to my simple queues. I tried to disable all mangle and queues but traffic is still passing to mikrotik. What should I do to prevent this from happening.
Sorry for my english.
WAN → Mikrotik Hex GR3 → 16PORT unmanaged Gbe switch connected to Hex eth2 port.
So your router is connected to switch with single ethernet cable, connected to ether2? Unless PC01 and Server are in different subnets (and RB has two IP addresses set on ether2/bridge) this definitely should not happen. If it does, it’s due to mis-configuration on either PC01 or Server or both. Otherwise the dumb switch should pass traffic between PC01 and Server directly without bothering router.
