Hi
I have a Mikrotik RB951Ui-2HnD with this configuration
Ether 1 is WAN
Ether 2 is LAN
Mikrotik have an internet connection but LAN doesn’t have.
What can i do
Hi
Ether 1 is WAN
Ether 2 is LAN
What can i do
First of all, update your device to at least the latest stable version. Currently, it’s 6.43.12.
Without all current configuration, it is hard to tell where the problem is exactly, so recheck:
If you still have issues, please provide your configuration, edit/remove the sensitive information before posting it.
Also, if you are configuring the device with no default configuration, please don’t leave the Firewall without proper and secure configuration.
post your config
/export hide-sensitive file=yourconfigfeb25
The easy way could be if you use default configuration just set up your WAN interface like you did. Plug at your WAN into ether1.
HI
In the file is all the configuration. The mikrotik have internet conexion, but not the other ether. i think could be and DNS problems but can you tell me what i have to check?
Can be a problem with mi equipment?
default gateway is the IP of the equipment that the ISP provide me
Config.docx (150 KB)
tick allow remote requests.
did you set up dhcp-server?
please post config (not half snapshots)
/export hide-sensitive file=yourconfigfeb26
yes i have a dhcp-server for the ether 2 (LAN)
