Landing page not working from WAN
Hi Guys
I have setup 13 stores country wide with routerboards and hotspots.
They are all done exactly the same as I copied the config from the first board to all others and just updated the script.
The board dials in the pppoe for the ADSL and I have a script running to update the dynamic dns for the public IP.
when i access the dyndns URL in my browser i get the landing page on some boards as I should but not on others.
I need to be able to access userman on each board via the web interface so that the store manager can add/delete users themselves.
I cant see how the one would work and the other doesn’t , is there something I am missing?
I will post any logs or anything you guys want to help solve the problem.
PLEASE HELP :confused:
Hi there,
Plese post export config from 2 devices, one that work and one that does not
/ip hotspot export
/ip service export
/ip firewall filter export
Pawel
ok cool here we go -
here is the non-working one
/ip hotspot export
/ip hotspot profile
set default dns-name=“” hotspot-address=0.0.0.0 html-directory=hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap name=default rate-limit=“”
smtp-server=0.0.0.0 split-user-domain=no use-radius=no
add dns-name=gateway.dionwired.co.za hotspot-address=192.168.0.129 html-directory=hotspot http-cookie-lifetime=5m http-proxy=0.0.0.0:0 login-by=cookie,http-chap name=
hsprof1 nas-port-type=wireless-802.11 radius-accounting=yes radius-default-domain=“” radius-interim-update=received radius-location-id=“” radius-location-name=“”
radius-mac-format=XX:XX:XX:XX:XX:XX rate-limit=“” smtp-server=64.13.232.144 split-user-domain=no use-radius=yes
/ip hotspot
add address-pool=dhcp_pool2 addresses-per-mac=1 disabled=no idle-timeout=5m interface=wlan2 keepalive-timeout=none name=hotspot1 profile=hsprof1
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=4 status-autorefresh=1m transparent-proxy=no
/ip hotspot service-port
set ftp disabled=no ports=21
/ip hotspot walled-garden
add action=allow comment=“place hotspot rules here” disabled=yes
add action=allow comment=twitter disabled=no dst-host=twitter server=hotspot1
add action=allow comment=mweb disabled=no dst-host=mweb server=hotspot1
add action=allow comment=dionwired disabled=no dst-host=dionwired server=hotspot1
add action=allow comment=“twitter images” disabled=no dst-host=twimg server=hotspot1
add action=allow comment=“facebook backend” disabled=no dst-host=fbcdn server=hotspot1
add action=allow comment=“facebook backend” disabled=no dst-host=facebook server=hotspot1
add action=allow comment=twitter disabled=no dst-host=webtrix server=hotspot1
add action=allow comment=twitter disabled=no dst-host=youtube server=hotspot1
add action=allow comment=twitter disabled=no dst-host=itunes server=hotspot1
add action=allow comment=twitter disabled=no dst-host=sony server=hotspot1
add action=allow comment=twitter disabled=no dst-host=toshiba server=hotspot1
add action=allow comment=twitter disabled=no dst-host=canon server=hotspot1
add action=allow comment=twitter disabled=no dst-host=samsung server=hotspot1
add action=allow comment=twitter disabled=no dst-host=intel server=hotspot1
add action=allow comment=twitter disabled=no dst-host=apple server=hotspot1
add action=allow comment=“youtube images” disabled=no dst-host=ytimg server=hotspot1
add action=allow comment=dionwired disabled=no dst-host=youtu.be server=hotspot1
add action=allow comment=twitter disabled=no dst-host=google server=hotspot1
add action=allow comment=twitter disabled=no dst-host=img server=hotspot1
/ip hotspot walled-garden ip
add action=accept disabled=no server=hotspot1 src-address=64.13.232.144
add action=accept disabled=no dst-address=64.13.232.144 server=hotspot1
add action=accept disabled=no server=hotspot1 src-address=196.4.160.4
add action=accept disabled=no dst-address=196.4.160.4 server=hotspot1
add action=accept disabled=no server=hotspot1 src-address=66.102.13.101
add action=accept disabled=no dst-address=66.102.13.101 server=hotspot1
ip service export
/ip service
set telnet disabled=no port=23
set ftp disabled=no port=21
set www disabled=no port=80
set ssh disabled=no port=22
set www-ssl certificate=none disabled=yes port=443
set api disabled=yes port=8728
set winbox disabled=no port=8291
[admin@WoodMead] >
add action=passthrough chain=unused-hs-chain comment=“place hotspot rules here” disabled=yes
[admin@WoodMead] >
And here is the one that does work -
/ip hotspot profile
/ip hotspot
add address-pool=dhcp_pool2 addresses-per-mac=1 disabled=no idle-timeout=5m interface=wlan1 keepalive-timeout=none name=hotspot1 profile=hsprof1
[admin@HydePark] >
/ip service
[admin@HydePark] >
Cool thanks a lot for your help
seem to be ok and same on both ,
Do you have any other equipment routers that are diffrent on both locations ? maybe they bloch access to www on RB
No , all the stores have the exact same setup with Hardware.
We did all the stores in one go , so we bought 13 sets of the exact same equipment , I did the first setup and it worked and then just copied everything across to all other boards.
it is very very strange.
I can winbox into every board no problem , its just the www that doesnt work from WAN!
