Hi normis,
concerning my post, have you an idea ?
Bests regards
Hi normis,
Bests regards
I am Czech user, and i have same problem as routeurspot.
I read the wiki, just i don’t know if i must to create a folder on my router ? I translated file en_EN_def.txt and i uploaded file “cz_CZ.lng” to RB600A with routeros 4.5.
then logon, with subscriber (owner permisions) or user mode, no select box appears with language selection
any ideas?
thank you!
i have same problem that petr799, but with RB800 and ver4.5 too…
attached i have the sp lang…
Sp_SP_def.txt (19.2 KB)
Hi gays!
I have RB433AH, routeros v4.6,try set Russian language to user manager.
I reed this http://wiki.mikrotik.com/wiki/User_Manager/Languages end do it.
Upload the file ru_RU.lng using ftp to root directory RB.
But language select box no it!
Where find problem?
rtl8186,
please user manager test package, then language will be supported.
http://forum.mikrotik.com/t/user-manager-v4-0-test-package/32132/1
sergejs thanks!!
I’am install userman-test packeges,but Language support don’t work ![]()
rtl8186, we are still waiting for access to your User Manager.
i’m using v4.6 and i have exactly same problem
can someone help? same situation is when i have .lng extension only (when i saving as in Poedit i change file type on all files, and then type extension .lng in file name) also, when i log in as a user, and when i click on Settings, i get message like on picture :S:S
The problem is known and it will be fixed in the upcoming versions. (promised by Sergejs, tks for support)
Regards
João Olival
Может кому пригодиться…
ru_RU.rar (4.9 KB)
