Large D/L Bandwidth loss with VPN
Hi, running bandwidth tests with and without connecting to remote AHx2 from local RB2011-UiAS-2Hnd
No VPN:
/tools => bandwidth test running from the Local RB2011UiAS-2Hnd:
PPTP VPN:
/tools => bandwidth test running from the remote AHx2:
AHx2 CPU: 1% when running bandwidth tests
AHx2 Internet Connection: 1GB DL/ 50MB UL
RB2011 CPU: 39% when running tests
RB2011 Internet Connection: 100MB DL/ 10MB UL
Need much better D/L via VPN. The MT hAP AC was suggested as a replacement but the CPU power between the local RB2011 and the hAP AC is not significant. I don’t think the hAP AC will be able to produce that much better results.
Wondering if anyone has suggestions to get better bandwidth results via VPN
For what you use the VPN,
Why you use PPTP in 2017, it is not save
Without more Information no answer possible
