Hi All
I am having a very large HW Frame vs Frames rate difference on one of my PTP links and am wondering if this could be caused by alignment? I have noticed that the Rx Rate keeps fluctuating between 6Mbps and 300Mbps. The two devices (SXT 5nD r2) are quite close to each other so I had to turn down the power to 10 to get signal to sit at -40. If I use winbox to connect to the remote device it keeps dropping the whole time however if I ping it the ping sits at 1ms with zero packet loss. Any suggestions would be really appreciated.
Signal Info (nstreme):
Tx/Rx Signal Strength -38/-38 dBm
Tx/Rx Signal Strength Ch0 -39/-39 dBm
Tx/Rx Signal Strength Ch1 -44/-46 dBm
Tx/Rx Signal Strength Ch2
Signal To Noise 72 dB
Tx/Rx CCQ 97/96 %
P Throughput 47003 kbps
HW Frames/Frames
