Large route table, removing a static
Perhaps this has been answered before, I tried searching for it but so far I’ve come up empty.
I have a CCR with ~2.5 million routes ( BGP, OSPF etc. ) it also has a handful of static routes… how can I modify a static route? The ID value is constantly changing with BGP etc.
Thanks,
simply specify the actual value as parameters for change,
first example:
/ip route set > parameters=value > [find where comment=“actual comment” and distance=1 and dst-address=1.11.23.0/24 and gateway=89.22.121.4 and pref-src=89.22.121.2]
inside you can omit or place any parameters, but do not place less than identifyng correctly the route.
second example:
identify each static route with one comment, like “RT0000023” or “RT0000023 never mind about other comment here” (for unique comment ID use only letters and numbers, and use “0” as placeholders)
and do tis:
/ip route set > parameters=value > [find where comment~“RT0000023”]
Thanks! now, does this work for remove too? I know you could do this for a set but… never tried this with a remove.
Yes:
/ip route > remove > [find where comment=“actual comment” and distance=1 and dst-address=1.11.23.0/24 and gateway=89.22.121.4 and pref-src=89.22.121.2]
/ip route > remove > [find where comment~“RT0000023”]
but I prefer:
/ip route > set disabled=yes > [find where comment=“actual comment” and distance=1 and dst-address=1.11.23.0/24 and gateway=89.22.121.4 and pref-src=89.22.121.2]
/ip route > set disabled=yes > [find where comment~“RT0000023”]
and after some days if all works I remove disabled routes
I can confirm both of those examples work. You rock, thank you!
Nothing, and thanks for karma!
I know it is an old topic. Any changes which speeds up route changes/removals with big routing tables.
Esp. with a pending problem it is crazy to sit there waiting minutes until a command finishes.
Yes this is my main complaint with Mikrotik at the core at the moment - it can import full tables in good-enough time but convergence is slow as when adding routes or removing routes - up to 5-10 minutes for me with about 1million BGP routes (With some static). I couldnt imagine running a CCR with multiple full transit feeds i.e. upwards of 2milliion routes, just because convergence time will take way too long.
Hopefully this is something that be improved in due time - not sure if its a kernel limitation on current network stack or not.
We are working on improvments.
