latency in PPPoE connections
Hi all!
I started to use PPPoE last week in my customers that are using 5.8Ghz radios. With fixed IP Address I’ve the latency between 1ms and 5ms and when I setup PPPoE the latency is between 30ms and 40ms.
The PPPoE server is a RB1000 and the server is running on the ether2. The local IP address is on ether2 interface. I’ve about 50 PPPoE connections together.
How can I solve this problem?
We had the same problem when using encryption with PPPoE sessions. When disabling encryption it resolved it for us. We used a RB450G as the PPPoE server and Ubiquity devices as clients.
Thanks riaanmaree,
But I don’t use encryption in my PPPoE sections.
I don’t know what is the problem… I’m looking for a solutions.
Fabrício
Hi Fabricio, did you found an answer to this issue? We are experiencing the same here.
Regards
J. Boardman
