Hi all,
we are testing a rb532 in ap-bridge mode, with wpa2, nstreme, polling. Framer policy was exact-size.
Clients are some rb112. Latency between the devices is about 20-24ms.
Will putting a pc insted of a rb532 bring the latency to 4-5ms ?
If we disable the nstreme obtain 2-3ms ping.
I think that the cause is the small cpu of rb532.
Someone with a simil configuration can post its ping ?
There doesn’t seem to bee to many people with this set up out there yet. My self and several other are working on rolling out some stuff this spring. From my bench testing results and other things I have heard the best way seem to be to go with a PC P4M at 1.5ghz or better. The 532 just don’t really have the power to do a proper ap with nstreme polling. Can’t tell you what the latency will be but in theory it should be a more stable then with out nstreme all though it is likely to be higher then a lightly load non nstreme AP. The systems should also scales much better then a non nstreme system
We have a small 8 use 802.11b network which we will slowly be moving to all rb112 boards. When that is complete we will be moving to nstreme for testing. How ever the AP is a 532. We will be over clocking it to boost its power when the time comes. I’ll post our results in a few months as things get ramped up.
Here we have a lot of motorola canopy system that causes packet loss also with very good signal (-62dbm).
Enabling nstreme with polling or using something like osbridge polling protocol will solve this issue.
But on a 40 metres antenna tower is very difficult to have a celeron , and rb532 have very poor performance !!
I’m actually setting up a backhaul network utilizing an SR5 as the primary AP and remote nodes with RB532/SR5 combos. The network configuration is 5Ghz-Turbo/WPA2/nstream polling best-fit 3200.
Latency IN THE LAB is less than 10ms. This system has not yet been deployed.
But on a 40 metres antenna tower is very difficult to have a celeron Smile, and rb532 have very poor performance !!
Actually, it’s not that hard. Just find yourself a micro ATX board which should fit in this case and use a DC-DC power supply, a few RB11 boards and put whatever miniPCI’s in you need. Voila!
We just upgraded from an RB532 to a Via 600MHz motherboard using Nstreme w/WDS and polling. Ping times still suck and can go from 20ms to 140ms with 32 clients registered. The problem occurs with both CM9, R52 and SR5 cards. Different frequencies don’t help either and we have >90% CCQ.
So it appears this is an Nstreme or WDS issue. We’ll try turning off Nstreme to see if it fixes the problem.
Anyone played with Nstreme polling on 3.0? On a desk top trial using just 2 112 boards and the new bridge mode and a pair of SR9’s I was seeing around 23-25mbps with no tweaking, and only a 6mbps return channel, one pc was also just a p3. The cool part was the processors were not maxed out. They ran in the 60-80% range! I’m going to put on a real antenna so I have a solid 54/54 and do some tweaking… but results look very good. We hope to be testing a 8 users (live) network with in the next week or two (532ap and all 112 clients) just have to clean up some of the installs and up grade 4 more senao b boxes. We’ll start with 2.9.x 9 (nstreme) and then try 3.0, using the new bridge nstreme and turn off the collision detect (CDMA) There is a few issues loading 3.0 on the 112 right now so we will probably wait until 3.0beta6 for a fix to make life simpler. I’ll post when done.
