latency on NV2 PTP links
Hello. How to reduce ping on PTP links with NV2?
When TDMA is reduced, then is reduced throughput. That is NOT solution.
For example when PTP link is 2km. How to reduce cell radius? Mimimum value is 10km. Why?
Have you plan to reduce ping for PTP NV2 links?
I’m curious as to what ping times you are trying to achieve. We run VoIP and audio feeds from local radio stations to their tower sites and NV2 works great and averages 5ms pings over 10 miles. Seems pretty good to me. but interference will make ping times climb out of the normal range.
Regards,
Josh
Yes, 1 link no problem. But 4-5 NV2 links in a row. That is problem.
Nstream and 802.11 have better ping. But NV2 have better stability and throughput. We need better ping for NV2 P2P
Hello Honzam,
Maybe you should use Rocket M? :slight_smile: :slight_smile: :slight_smile:
It is an “extreme” solution. Better is when mikrotik find solution.
Please solve better ping on NV2 links and TCP problem
On ptp I use ubnt gear…where nstreme or nstreme dual is not working…
It seems, one guy already have diagnosed tcp problem.
http://forum.mikrotik.com/viewtopic.php?f=7&t=66380&start=50#p350398
Lets wait until mikrotik will read this post :slight_smile:
Unfortunately, none of the Mikrotik support does not read it
