I have a RB433, after loading ROS 5.5 I tried to update the firmware.
After that the RB433 would not boot. I connected a serial cable, and got a
"RouterBOOT booter 2.20
RouterBoard 433
Authorization: Passed
CPU frequency: 300 MHz
Memory size: 64 MB
Press any key within 5 seconds to enter setup…
loading kernel from nand… OK
setting up elf image… OK
jumping to kernel code
Kernel panic - not syncing: Attempted to kill init! "
It seems the firmware is broken.
Where can i get a coppy of the firmware please?
Thank you.
