latest RouterOS for RB1100
Hi there,
Does anyone know the latest version for the RB1100 and where this can be downloads from.
i am having issues, hotspot seems to be handing out IP but no users are able to surf. nor is there any splash screen that shows up
within the browser for authentication, a quick disable and then enable will fix things, happens about every 2 days or so. Just thinking
that upgrading the ROS will fix this problem, currently running ROS 4.7
Thank you.
http://www.mikrotik.com, click the Download tab
Latest stable is 4.11, latest beta is 5.0beta6
Thank you.
I may have to revert back to a stable 4.11 ROS for now to see if it will correct the issue. Why do I not see ROS 4.7 available for download?
Thanks.
Because it’s an old version. 11 is a later rev than 7, so 4.11 is more recent than 4.7.
Yes. i see now, thank you. it is very clear now. for some reason I was thinking 4.1.1, not the case.
I will post if the upgrade fixes the Hotspot user issues.
Cheers!
