hi guys…
anybody tested layer 2 isolation on wireless interfaces ?
never mind if “default forward” is enabled or disabled… I see my neighbors pc…
and can get little dirty pictures…
… no..
but where is the problem ?
regards
gerd
hi guys…
… no..
regards
gerd
i got it …
it is only if i enable wds…
without wds isolation is ok…
but … if wds is enabled isolation is not working… is that ok ?
regards
gerd
OK
If you need isolation between interfaces use bridge firewall.
hello… ![]()
i need it very well…
can you tell me the rule for the bridge ? i don´t find something about that in manual…
thanks a lot
gerd
i got it… thanks
Hello guy, can you tell me the rule please.
Thanks!
for wireless isolation you should use the access list. just add a rule in there with forward=no
