Layer 2 Traffic Priorization
Hi everyone,
I am in a middle of a project where i have to connect many security cammeras (CCTV) through Wireless and Fiber Optic network. Everything will be transparent (Bridged), and I need to priorize the PTZ traffic (Traffic from the joystick to move the cammera (TCP)) over the UDP video traffic.
At first i try using in the bridge the option use-firewall= yes, and then put some mangle rules and queue rules. But did’t work, the counters of each rule works fine, and the packet mark did work too, but if i increase the traffic of the cammeras then the PTZ traffic go slow.. too slow. So did’t work.
Do you know another way to priorize packets over a bridged network. I read something of 802.1p but i don’t know if mikrotik support that, i did’t found a example or a good explanation of layer 2 priorization in the Mikrotik’s Manual.
I will appreciate your concern. I will wait for an answer
Thank You
Anyone? Mikrotik People… what do you think?.. some idea?
I will appreciate some opinion.
maybe this helps: http://www.tiktube.com/?video=247
I done this project.
My CCTV:
example:
http://192.168.0.1:123
http://192.168.0.1:124
-Mikrotik:
/ip firewall nat (80:udp)
Sophal What are you talking about?
Sorry but i did´t understand what you try to tell me.
I manage security cammeras Traffic from the joystick to move the cammera (TCP)) over the UDP on mikrotik router.
see more:
http://wiki.mikrotik.com/wiki/Talk:Forwarding_a_port_to_an_internal_IP
