Hi
I have a more complicated setup i need some help with, we have to migrate an office with as less downtime as possible and i need some help configuring this:
I have used mikrotik routers for some time now, because every time i need a twisted solution i can use them over cisco or other brands.
The setup:
old office Lan ----------- mikrotik ------------juniper ssg20----------Internet -------- Juniper SSG20 ------ Mikrotik ----- new office lan
I am configuring a pptp between the 2 routers, but i need a layer 2 connection over it between the mikrotiks so i can have the same subnet on both locations during the movement.
The board does not want to get rid of those crappy SSG20, and those 2 routers are useless. I could maybe use at the new office only the mikrotik for the movement.
I have tried PPP tunnel bridging (BCP), Eoip, and VPLS followng this guide (don’t know mpls):
http://wiki.mikrotik.com/wiki/Transparently_Bridge_two_Networks_using_MPLS
I get a dhcp address from my old office, i can do anything inside the local subnet, but i have problems going out on the internet and i am guessing it is because of the MTU. Small pages like google.com work, but pages like microsoft.com do not.
With ping -f -l 1430 i get a reply, but bigger mtu gets discarded using BCP
I also need port forwarding to reach the servers i move in the new offices.
Basically this is a transparent bridge across 2 networks. If someone could steer me in the right direction i would really appreciate it.
Also i would like to know which is better for this job: eoip/VPLS/BCP
Thank you
