Is it possible to setup layer 3 roaming?
I have setup Capsman (main network router as server) whit CAPs on separate VLANs, if client device roams it gets a new IP. It is fine for me at home lab, but it can cause issues if I deploy this configuration at work.
My configuration:
# aug/02/2020 00:07:19 by RouterOS 6.47.1
# software id = BVLC-I6J1
# model = RB450Gx4
# serial number =
/caps-man channel
add band=2ghz-onlyn control-channel-width=20mhz extension-channel=disabled \
frequency=2412 name=CH1
frequency=2417 name=CH2
frequency=2422 name=CH3
frequency=2427 name=CH4
frequency=2432 name=CH5
frequency=2437 name=CH6
frequency=2442 name=CH7
frequency=2447 name=CH8
frequency=2452 name=CH9
frequency=2457 name=CH10
frequency=2462 name=CH11
frequency=2467 name=CH12
frequency=2472 name=CH13
add band=5ghz-onlyac frequency=5180 name=CH36
add band=5ghz-onlyac frequency=5200 name=CH40
add band=5ghz-onlyac frequency=5220 name=CH44
add band=5ghz-onlyac frequency=5240 name=CH48
add band=5ghz-onlyac frequency=5260 name=CH52
add band=5ghz-onlyac frequency=5280 name=CH56
add band=5ghz-onlyac frequency=5300 name=CH60
add band=5ghz-onlyac frequency=5320 name=CH64
add band=5ghz-onlyac frequency=5500 name=CH100
add band=5ghz-onlyac frequency=5520 name=CH104
add band=5ghz-onlyac frequency=5540 name=CH108
add band=5ghz-onlyac frequency=5560 name=CH112
add band=5ghz-onlyac frequency=5580 name=CH116
add band=5ghz-onlyac frequency=5600 name=CH120
add band=5ghz-onlyac frequency=5620 name=CH124
add band=5ghz-onlyac frequency=5640 name=CH128
add band=5ghz-onlyac frequency=5660 name=CH132
add band=5ghz-onlyac frequency=5680 name=CH136
add band=5ghz-onlyac frequency=5700 name=CH140
add band=5ghz-onlyac frequency=5745 name=CH149
add band=5ghz-onlyac frequency=5765 name=CH153
add band=5ghz-onlyac frequency=5785 name=CH157
add band=5ghz-onlyac frequency=5805 name=CH161
add band=5ghz-onlyac frequency=5825 name=CH165
add admin-mac=C4:AD:34:75:CA:B0 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] comment=WAN mac-address=74:4D:28:78:2A:17
set [ find default-name=ether2 ] comment="Maigo\F2a ala"
set [ find default-name=ether3 ] comment="Mened\FEments"
set [ find default-name=ether5 ] comment="Mammas istaba/POE"
/interface vlan
add comment="Maigo\F2a ala vadi" interface=ether2 name=\
vlan10_maigonja_ala_vadi vlan-id=10
add comment="Maigo\F2a ala 5ghz" interface=bridge name=\
vlan11_maigonja_ala_5ghz vlan-id=11
add comment="Maigo\F2a ala 2.4ghz" interface=bridge name=\
vlan12_maigonja_ala_2.4ghz vlan-id=12
add comment="Mammas istaba 5ghz" interface=bridge name=\
vlan20_mammas_istaba_5ghz vlan-id=20
add comment="Mammas istaba 2.4ghz" interface=bridge name=\
vlan21_mammas_istaba_2.4ghz vlan-id=21
/caps-man rates
add basic=24Mbps ht-basic-mcs=mcs-3 ht-supported-mcs="mcs-3,mcs-4,mcs-5,mcs-6,\
mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,\
mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23" name=ieteicamie supported=\
24Mbps,36Mbps,48Mbps,54Mbps vht-basic-mcs="" vht-supported-mcs=""
add basic="1Mbps,2Mbps,5.5Mbps,11Mbps,6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,\
48Mbps,54Mbps" name=visi supported="1Mbps,2Mbps,5.5Mbps,11Mbps,6Mbps,9Mbps\
,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps"
add basic=12Mbps ht-basic-mcs=mcs-1 ht-supported-mcs="mcs-1,mcs-2,mcs-3,mcs-4,\
mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mc\
s-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23" name=\
"ieteicamie 12" supported=12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps \
/caps-man configuration
add country=latvia datapath.bridge=bridge datapath.local-forwarding=no \
installation=indoor name=cfg1 rates=ieteicamie \
security.authentication-types=wpa2-psk security.disable-pmkid=yes \
security.encryption=aes-ccm security.group-encryption=aes-ccm ssid=\
Sleepnis
installation=indoor name=test rates=ieteicamie \
security.encryption=aes-ccm security.group-encryption=aes-ccm ssid=test
installation=indoor name=TV rates=ieteicamie \
Sleepnis_TV
/caps-man interface
add channel=CH6 channel.frequency="" channel.tx-power=11 configuration=cfg1 \
datapath.vlan-id=12 datapath.vlan-mode=use-tag disabled=no l2mtu=1600 \
mac-address=C4:AD:34:C5:F0:9B master-interface=none mtu=1500 name=\
"Maigonja ala 2.4Ghz" radio-mac=C4:AD:34:C5:F0:9B radio-name=C4AD34C5F09B
add channel=CH36 channel.tx-power=18 configuration=cfg1 \
datapath.client-to-client-forwarding=yes datapath.vlan-id=11 \
datapath.vlan-mode=use-tag disabled=no l2mtu=1600 mac-address=\
C4:AD:34:C5:F0:9C master-interface=none name="Maigonja ala 5GHz" \
radio-mac=C4:AD:34:C5:F0:9C radio-name=C4AD34C5F09C
add channel=CH11 channel.frequency="" channel.tx-power=10 configuration=cfg1 \
datapath.vlan-id=21 datapath.vlan-mode=use-tag disabled=no l2mtu=1600 \
mac-address=C4:AD:34:D9:4B:06 master-interface=none mtu=1500 name=\
"Mammas istaba 2.4Ghz" radio-mac=C4:AD:34:D9:4B:06 radio-name=\
C4AD34D94B06
add channel=CH100 channel.tx-power=18 configuration=cfg1 datapath.vlan-id=20 \
C4:AD:34:D9:4B:07 master-interface=none name="Mammas istaba 5Ghz" \
radio-mac=C4:AD:34:D9:4B:07 radio-name=C4AD34D94B07
add channel=CH36 channel.frequency=5180 channel.tx-power=18 configuration=TV \
C4:AD:34:C5:F0:9D master-interface="Maigonja ala 5GHz" name="TV SSID" \
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.100-192.168.88.254
add name=maigonja_ala_vadi ranges=192.168.1.10-192.168.1.254
add name=maigonja_ala_5ghz ranges=192.168.2.10-192.168.2.254
add name=maigonja_ala_2.4ghz ranges=192.168.3.10-192.168.3.254
add name=mammas_istaba_5ghz ranges=192.168.10.10-192.168.10.254
add name=mammas_istaba_2.4ghz ranges=192.168.11.10-192.168.11.254
add address-pool=dhcp disabled=no interface=bridge lease-time=8h name=defconf
add address-pool=maigonja_ala_vadi disabled=no interface=\
vlan10_maigonja_ala_vadi lease-time=8h name=dhcp_maigonja_ala_vadi
add address-pool=maigonja_ala_5ghz disabled=no interface=\
vlan11_maigonja_ala_5ghz lease-time=8h name=dhcp_maigonja_ala_5ghz
add address-pool=maigonja_ala_2.4ghz disabled=no interface=\
vlan12_maigonja_ala_2.4ghz lease-time=8h name=dhcp_maigonja_ala_2.4ghz
add address-pool=mammas_istaba_5ghz disabled=no interface=\
vlan20_mammas_istaba_5ghz lease-time=8h name=dhcp_mammas_istaba_5ghz
add address-pool=mammas_istaba_2.4ghz disabled=no interface=\
vlan21_mammas_istaba_2.4ghz lease-time=8h name=dhcp_mammas_istaba_2.4ghz
/queue simple
add disabled=yes max-limit=10M/10M name=queue1 target=\
/system logging action
set 1 disk-file-count=5
/caps-man access-list
add action=accept allow-signal-out-of-range=always disabled=yes interface=\
"Maigonja ala 5GHz" mac-address=F0:86:20:89:85:24 ssid-regexp=""
add action=reject allow-signal-out-of-range=10s disabled=yes interface=any \
add action=accept allow-signal-out-of-range=10s disabled=yes interface=\
"Mammas istaba 2.4Ghz" mac-address=40:CD:7A:D1:3B:20 ssid-regexp=""
"Mammas istaba 2.4Ghz" mac-address=B4:E1:C4:D3:40:AC ssid-regexp=""
"Mammas istaba 5Ghz" mac-address=D0:37:45:85:C5:F0 ssid-regexp=""
"Maigonja ala 2.4Ghz" mac-address=10:B1:F8:05:21:E2 ssid-regexp=""
add action=accept allow-signal-out-of-range=10s disabled=no signal-range=\
-70..120 ssid-regexp=""
add action=reject
/caps-man manager
set enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=bridge
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=cfg1
add address=192.168.88.1/24 comment=defconf interface=ether2 network=\
192.168.88.0
add address=192.168.1.1/24 comment="Maigo\F2a ala" interface=\
vlan10_maigonja_ala_vadi network=192.168.1.0
add address=192.168.2.1/24 comment="Maigo\F2a ala 5ghz" interface=\
vlan11_maigonja_ala_5ghz network=192.168.2.0
add address=192.168.3.1/24 comment="Maigo\F2a ala 2.4ghz" interface=\
vlan12_maigonja_ala_2.4ghz network=192.168.3.0
add address=192.168.10.1/24 comment="Mammas istaba 5ghz" interface=\
vlan20_mammas_istaba_5ghz network=192.168.10.0
add address=192.168.11.1/24 comment="Mammas istaba 2.4ghz" interface=\
vlan21_mammas_istaba_2.4ghz network=192.168.11.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1 use-peer-dns=no
/ip dhcp-server lease
add address=192.168.88.2 comment="Me\FEonis" mac-address=E0:D5:5E:A3:EF:5B \
server=defconf
add address=192.168.88.51 comment="cAP ac Mammas istaba" mac-address=\
C4:AD:34:D9:4B:04 server=defconf
add address=192.168.88.3 client-id=1:f0:86:20:89:85:24 comment="LG TV WiFi" \
disabled=yes mac-address=F0:86:20:89:85:24 server=defconf
add address=192.168.88.30 comment="Spuldz\EEte 1 Maigo\F2a ala" disabled=yes \
mac-address=04:CF:8C:A0:BF:2A server=defconf
add address=192.168.88.31 comment="Spuldz\EEte 2 Maigo\F2a ala" disabled=yes \
mac-address=04:CF:8C:A0:B6:4B server=defconf
add address=192.168.88.21 client-id=1:40:cd:7a:d1:3b:20 comment="Mammas TV" \
disabled=yes mac-address=40:CD:7A:D1:3B:20 server=defconf
add address=192.168.88.50 client-id=1:c4:ad:34:c5:f0:96 comment=\
"hAP ac2 Maigo\F2a ala" mac-address=C4:AD:34:C5:F0:96 server=defconf
add address=192.168.88.20 client-id=1:d0:37:45:85:c5:f0 comment=\
"Mammas dators" disabled=yes mac-address=D0:37:45:85:C5:F0 server=defconf
add address=192.168.88.4 client-id=1:64:95:6c:2d:1d:3a comment="LG TV LAN" \
disabled=yes mac-address=64:95:6C:2D:1D:3A server=defconf
add address=192.168.1.0/24 comment="Maigo\F2a ala vadi" dns-server=\
1.1.1.1,1.0.0.1 gateway=192.168.1.1
add address=192.168.2.0/24 comment="Maigo\F2a ala 5ghz" dns-server=\
1.1.1.1,1.0.0.1 gateway=192.168.2.1
add address=192.168.3.0/24 comment="Maigo\F2a ala 2.4ghz" dns-server=\
1.1.1.1,1.0.0.1 gateway=192.168.3.1
add address=192.168.10.0/24 comment="Mammas istaba 5ghz" dns-server=\
1.1.1.1,1.0.0.1 gateway=192.168.10.1
add address=192.168.11.0/24 comment="Mammas istaba 2.4ghz" dns-server=\
1.1.1.1,1.0.0.1 gateway=192.168.11.1
192.168.88.1
set allow-remote-requests=yes cache-size=1024KiB use-doh-server=\
https://1.1.1.1/dns-query verify-doh-cert=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
"At\EFaut savienojumu me\FEonim no 5ghz Maigo\F2a t\EEkla" dst-address=\
192.168.2.0/24 src-address=192.168.88.2
"At\EFaut savienojumu me\FEonim no 5ghz Maigo\F2a t\EEkla #2" \
dst-address=192.168.88.2 src-address=192.168.2.0/24
"At\EFaut savienojumu me\FEonim no 5ghz Mammas t\EEkla" dst-address=\
192.168.88.2 src-address=192.168.10.0/24
"At\EFaut savienojumu me\FEonim no 5ghz Mammas t\EEkla #2" dst-address=\
192.168.10.0/24 src-address=192.168.88.2
"Blo\ED\E7 vlan savstarp\E7jo savienojumu" in-interface=bridge \
out-interface=all-vlan
add action=masquerade chain=srcnat dst-address=192.168.88.0/24 src-address=\
192.168.88.0/24
add action=dst-nat chain=dstnat dst-port=63718 in-interface=ether1 protocol=\
tcp to-addresses=192.168.88.2 to-ports=63718
add action=dst-nat chain=dstnat comment=Aspia dst-port=5135 in-interface=\
ether1 protocol=tcp to-addresses=192.168.88.2 to-ports=5135
add action=dst-nat chain=dstnat comment=VNC dst-address=89.254.164.110 \
dst-port=61595 protocol=tcp to-addresses=192.168.88.2 to-ports=61595
add action=dst-nat chain=dstnat comment=Plex dst-address=89.254.164.110 \
dst-port=32400 protocol=tcp to-addresses=192.168.88.2 to-ports=32400
add action=dst-nat chain=dstnat disabled=yes dst-port=32400 in-interface=\
ether1 protocol=tcp to-addresses=192.168.88.2 to-ports=32400
add action=dst-nat chain=dstnat disabled=yes dst-address=89.254.164.110 \
add action=masquerade chain=srcnat disabled=yes out-interface=ether1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Riga
/system identity
set name="Sleepnja Kastiite"
/system logging
set 0 disabled=yes
set 1 disabled=yes
set 2 disabled=yes
set 3 disabled=yes
add action=disk topics=critical
add action=disk topics=error
add action=disk topics=info
add action=disk topics=warning
add action=disk disabled=yes topics=dhcp
add action=disk prefix=debug topics=wireless,debug
add action=disk prefix=debug topics=caps,debug
add action=disk topics=ntp
add action=disk disabled=yes topics=dns
/system ntp client
set enabled=yes primary-ntp=162.159.200.1
/system ntp server
set enabled=yes
/system scheduler
add interval=1d name="Auto Upgrade" on-event=\
"/system script run \"Auto Upgrade\"" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=nov/11/2019 start-time=03:00:00
/system script
add dont-require-permissions=no name="Auto Upgrade" owner=maigonis policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="#\
#\r\
\n## Automatically upgrade RouterOS and Firmware\r\
\n## https://github.com/massimo-filippi/mikrotik\r\
\n##\r\
\n## script by Maxim Krusina, maxim@mfcc.cz\r\
\n## based on: http://wiki.mikrotik.com/wiki/Manual:Upgrading_RouterOS\r\
\n## created: 2014-12-05\r\
\n## updated: 2019-01-26\r\
\n## tested on: RouterOS 6.43.8 / multiple HW devices\r\
\n##\r\
\n########## Set variables\r\
\n## Update channel can take values before 6.43.8: bugfix | current | d\
evelopment | release-candidate\r\
\n## Update channel can take values after 6.43.8: long-term | stable | d\
evelopment | testing\r\
\n:local updChannel \"stable\"\r\
\n## Notify via Slack\r\
\n:local notifyViaSlack false\r\
\n:global SlackChannel \"#log\"\r\
\n## Notify via E-mail\r\
\n:local notifyViaMail false\r\
\n:local email \"your@email.com\"\r\
\n########## Upgrade firmware\r\
\n## Let's check for updated firmware\r\
\n:local rebootRequired false\r\
\n/system routerboard\r\
\n\r\
\n:if ( [get current-firmware] != [get upgrade-firmware]) do={\r\
\n\r\
\n ## New version of firmware available, let's upgrade\r\
\n ## Notify via Log\r\
\n :log info (\"Upgrading firmware on router \$[/system identity get nam\
e] from \$[/system routerboard get current-firmware] to \$[/system routerb\
oard get upgrade-firmware]\")\r\
\n ## Notify via Slack\r\
\n :if (\$notifyViaSlack) do={\r\
\n :global SlackMessage \"Upgrading firmware on router *\$[/system i\
dentity get name]* from \$[/system routerboard get current-firmware] to *\
\$[/system routerboard get upgrade-firmware]*\";\r\
\n :global SlackMessageAttachements \"\";\r\
\n /system script run \"Message To Slack\";\r\
\n }\r\
\n ## Notify via E-mail\r\
\n :if (\$notifyViaMail) do={\r\
\n /tool e-mail send to=\"\$email\" subject=\"Upgrading firmware on \
router \$[/system identity get name]\" body=\"Upgrading firmware on router\
\_\$[/system identity get name] from \$[/system routerboard get current-fi\
rmware] to \$[/system routerboard get upgrade-firmware]\"\r\
\n }\r\
\n ## Upgrade (it will no reboot, we'll do it later)\r\
\n upgrade\r\
\n :set rebootRequired true\r\
\n\r\
\n}\r\
\n\r\
\n\r\
\n########## Upgrade RouterOS\r\
\n\r\
\n## Check for update\r\
\n/system package update\r\
\nset channel=\$updChannel\r\
\ncheck-for-updates\r\
\n## Wait on slow connections\r\
\n:delay 15s;\r\
\n## Important note: \"installed-version\" was \"current-version\" on olde\
r Roter OSes\r\
\n:if ([get installed-version] != [get latest-version]) do={\r\
\n :log info (\"Upgrading RouterOS on router \$[/system identity get nam\
e] from \$[/system package update get installed-version] to \$[/system pac\
kage update get latest-version] (channel:\$[/system package update get cha\
nnel])\")\r\
\n :global SlackMessage \"Upgrading RouterOS on router *\$[/system i\
dentity get name]* from \$[/system package update get installed-version] t\
o *\$[/system package update get latest-version] (channel:\$[/system packa\
ge update get channel])*\";\r\
\n }\r\
\n\r\
\n /tool e-mail send to=\"\$email\" subject=\"Upgrading RouterOS on \
router \$[/system identity get name]\" body=\"Upgrading RouterOS on router\
\_\$[/system identity get name] from \$[/system package update get install\
ed-version] to \$[/system package update get latest-version] (channel:\$[/\
system package update get channel])\"\r\
\n }\r\
\n ## Wait for mail to be sent & upgrade\r\
\n :delay 15s;\r\
\n install\r\
\n} else={\r\
\n :if (\$rebootRequired) do={\r\
\n # Firmware was upgraded, but not RouterOS, so we need to reboot \
to finish firmware upgrade\r\
\n :global SlackMessage \"Rebooting...\";\r\
\n }\r\
\n /system reboot\r\
\n } else={\r\
\n # No firmware nor RouterOS upgrade available, nothing to do, jus\
t log info\r\
\n :log info (\"No firmware nor RouterOS upgrade found.\")\r\
\n :global SlackMessage \"No firmware nor RouterOS upgrade foun\
d.\";\r\
\n }\r\
\n }\r\
\n}"
add dont-require-permissions=yes name=netdownreboot owner=maigonis policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":\
if ([/ping 8.8.8.8 interval=5 count=60] =0) do={\r\
\nlog info \"my ping watchdog is down\" ; /system reboot\r\
\n}"
/tool mac-server
/tool mac-server mac-winbox
/tool netwatch
add down-script="/system script run netdownreboot" host=8.8.8.8
/tool romon
set enabled=yes
PS; VLAN implementation is a bit messy and not complete right now, ignore that. I will sort that out later.
