Not an expert as @rextended is, but let me give you my point;
as you I’m using external DNS service for my router, and I want to make sure some stupid devices are not using other services, redirect DNS requests from LAN devices to port 53 it’s easy using NAT firewall rules;
DoT, drop dst-port=853 from RAW + tls-host=!nextdns (my Android phone is using NextDNS and I don’t want to be blocked)
DoH, drop dst-port=443 from RAW + dst-address-list=“DoH list”
this list contains IP addresses from CloudFlare and you’ll block also some websites
what I’m still learning is if tls-host= is useful, browsers are using DoH via TLS1.3 encrypted (thanks rextended for the info in a previous post) if you use tls-host exception for DoH rule this will be ignored, not problem with phones that are using DoT or DoH with TLS1.2 (still testing this).
If you use DoH with Chrome browser and you drop DoH IP addresses it’s not switching to the standard DNS, Firefox is.
The answer still “Forget it”, because Layer7 on https is completely useless,
and, ignoring than is not what is requested, use firewall rule to drop incomplete DoH list, is useless…
For example, (I just check) on Firefox is included NextDNS DoH resolver, that use dynamic CDN IPs,
and the list can not have the same IPs used also for distribute windows update, youtube videos, or other useful services,
that do not have any to do with DoH, but are on same CDN…
The idea here is to have a block for DoH requests that is dynamic, the “block list” needs constant update and searching and as rextended pointed out you risk to block something else too.
So i guess the thread is “solved” but i ask if you have any possible suggestions to block DoH forward requests or i should use a firewall.
Il problema finale risiede nel fatto che il DoH è stato creato proprio per non essere filtrato:
Usa una porta che se la blocchi, blocca tutto il traffico,
usa IP su CDN che se li blocchi blocchi anche altri servizi.
È per questo che è nato, e lo fa bene…
(in realtà è nato per prendere per il culo la gente con una presunta privacy, in modo di cercare di prendere il controllo dei DNS… chi controlla i DNS controlla il mondo…)
[EN]
The “final problem” lies in the fact that the DoH was created precisely to not be filtered:
Use a door that blocks it, blocks all traffic,
it uses IP on CDN which if you block them blocks other services as well.
That’s why he was born, and he does it well…
(actually it was born to bullshit people with alleged privacy, in order to try to take control of the DNS… who controls the DNS controls the world…)
