Good morning, I’ve the next problem: I have two gateways connect to my Mikrotik LB-532. When I connect just one, all services run perfectly, but if I connect both, same services fail.
Example: I drop all rules. I only connect a gateway. I have defined same rules in /ip firewall nat under this gateway. I prove all services and they run very well. The problem comes when I connect the second gateway. At this moment, I try to prove same services (webs, vpn’s server, ), and same of then don’t run. ¿What’s happened?
I can’t understand it.
Thanks.
