w0lt
March 9, 2013, 4:10pm
1
I’ve noticed I have an LCD configuration in the menu of my RB2011UAS-RM when using WinBox, but it does not show on my other RB2011UAS-2HnD…
ROS: 6.0rc11
I have the standard packages loaded, bear in mind, “No LCD” package loaded on either. Bug?
-TP
becs
March 11, 2013, 7:13am
2
It will be added for RB2011UAS-2HnD in one of the next RouterOS v6.0 releases.
jifop
November 11, 2013, 2:15pm
3
do you know when this might happen? It would be very useful…
normis
November 11, 2013, 2:21pm
4
LCD package is not required for RB2011 touchscreen menu to show up. It should be located in the left parent menu, called LCD, below New Terminal.
jifop
November 11, 2013, 3:01pm
5
odd its defiantly not there in winbox or webfig and I’m running the latest firmware…
normis
November 12, 2013, 6:48am
6
please email us your supout.rif file to support@mikrotik.com , we will check what has happened
Same problem with a RB2011UiAS-RM and ROS 6.4
No LCD in Winbox menu.
I have been using the RB2011UAS-RM and ROS 6.4 without any issues.
