LCD Default Mode at startup
Hi
Is it possible to set a default display mode for the LCD display.
I have routers I send out to customers and when they power on id like for them to automatically start up the informitive slideshow.
Is something like that possible or will this always require user interaction to press the desired button ?
Thanks.
Current model is rb2011-UAS-IN
You should be able to tell it what Interface to show and only that. Show Aggregate traffice, there are a few different options for a default screen. Or turn it off.
Thanks for the info.
We send these out to costumers we dont even want them to see the menu actually,. was hoping we could just get it set to automatically start the slide show that would show the date and minor details.
hopefully there will be some more functionality like that added in the future. again thanks for the reply
