LCD in 2.9.17 freezes
Hey all,
I’m wondering if there have been any reports of the LCD freezing. We’re noticing this in a box that has 2.9.17 running. From what we can determine the display works fine for a while and then freezes up when we make any configuration change however minor, and even sometimes it seems to occur when we haven’t made any changes. By ‘freezing’ I simply mean that the text on the screen is no longer updated (we have it displaying rate of transfer through a few of our uplinks).
Once the display as frozen we can unfreeze it by disabling and re-enabling the display through winbox.
I’m told that this wasn’t an issue before we upgraded from 2.9.10. Any ideas?
I was going to try upgrading to 2.9.18 (and likely will tonight) but according to the changelog there wasn’t anything to do with the LCD changed so I’m not expecting anything.
Thanks,
jeff
i have the same problem…
lcd is running fine…
then i just change anything in the MT config…
and the data stays the same… and the LCD freezes…
it’s a bug…
also in 2.9.18
can you both make supout.rif files the second after the LCD freezes? and then send them to support?
did that about 2 weeks ago, when i first noticed it…
running 2.9.17 then…
don’t see your email … did we reply?
should be fixed in 2.9.20
