kk.. This is weird..
got a LCD, if I use the output to LCD Script that is on the wiki it outputs, but no kewl data, just text.
If I turn on the LCD package, and configure it, garbley gook!
Ideas…
Ideas…
which display?
serial or paralell?
I have worked with many…
Sorry for the delay, it is a custom intergrated LCM and LCD module.
If I use the output to serial script, and specify NULL-MODEM=YES, then it outputs fine, but the intergrated unit has a 5 wire cable that is stright though, and I think that is my issue. I assume it thinks there is a null modem inline or something. ![]()
I am working with them to get the pin outs to see about flipping them on the connector, don’t know if it will work. but willing to try.
BTW, it is a serial intergrated unit, its one developed for the case that I have it in, so its not a standard display. Just figured since I could get it to write out, that the LCD package would be able to display on it.
Guess I was wrong!
Case Mfg / model?
