ldf 5 basic setup help
So I may not even be able to make this work like I want (I asked questions to the seller before buying and never got a response) but anyway.. my goal was to hook up the ldf 5 to my old satellite dish and connect it to my netgear router. And then with the amplified signal, I would be able to login to a free hotspot that’s a few hundred yards away.
I read on Amazon that someone did this with the lhg 5 successfully.
I tried hooking it up through the router and directly to my pc.. on my pc when I try to go to 192.168.88.1 it just says “no connection”. I even installed the mikrotik app and tried to login/discover the ldf and it doesn’t find anything.
It’s definitely getting power (green light is on). Could it be faulty or do I just have no idea what I’m doing? Is it even possible to do what I want or do I have to have a mikrotik router?
So I got it working (bad ethernet cable) but the signal is weak. The ldf picks up the same dozen wifi signals that I can pick up with my phone.
