I’ve just run into issue, when start to replace my switched backbone (RSTP) to OSPF/VPLS.
Started to pull access network from remote APs by VPLS tunnels to a RB1100AHx2 (currently running ROSv5.26)
to do queueing/dhcp server.
Sadly since first tunnels started to operate, the RB1100AHx2 rebooted sevaral times (daily). It had a 300+ day uptime before.
The log says:
System rebooted because of kernel failure
router was rebooted without proper shutdown
I’ve met with the same issue before with x86 (as i heard it’s still not fixed: http://forum.mikrotik.com/t/vpls-bug-in-x86-architecture/58651/1 )
Any of you have idea other than “upgrade, it may fix” ?
Thanks so much!
ps: Ticket#2015021166000379 (response: using very old release → upgrade)
