RouterOS version: 7.18.2
Model: RB5009
I’m really confused as to where does this prefix come from but I seem to always get an prefix from 2001::45a:2103::/64 but I cannot find it anywhere on my Router? The router advertisements from the Router include :2103 prefix but shouldn’t?
The network does include an Apple TV running with HomeKit.
# 2025-03-31 20:42:49 by RouterOS 7.18.2
add frame-types=admit-only-vlan-tagged name=bridge pvid=99 vlan-filtering=yes
set [ find default-name=ether1 ] poe-out=off
set [ find default-name=ether3 ] disabled=yes poe-out=off
set [ find default-name=ether4 ] poe-out=off
set [ find default-name=ether5 ] disabled=yes poe-out=off
set [ find default-name=ether6 ] disabled=yes poe-out=off
set [ find default-name=ether7 ] disabled=yes poe-out=off
set [ find default-name=ether8 ] comment="Management BACKUP" poe-out=off
set [ find default-name=sfp-sfpplus1 ] name=fiber-trunk
set [ find default-name=ether2 ] comment="LTE backup" name=wan2 poe-out=off
/interface wireguard
add listen-port=51821 mtu=1420 name=backdoor
add listen-port=51820 mtu=1420 name=home-vpn
/interface vlan
add interface=bridge name=IoT vlan-id=50
add interface=bridge name=KubeDev vlan-id=110
add interface=bridge name=KubeProd vlan-id=105
add interface=bridge name=MGMNT vlan-id=99
add interface=bridge name=MainLAN vlan-id=10
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=VLANs
add name=lan-dhcp-pool ranges=192.168.2.10-192.168.2.245
add name="management dhcp-pool" ranges=192.168.99.99-192.168.99.100
add name=iot-dhcp-pool ranges=10.0.50.30-10.0.50.100
add name=kubernetes-prod-dhcp-pool ranges=10.0.105.30-10.0.105.100
add name=kubernetes-dev-dhcp-pool ranges=10.0.110.20-10.0.110.30
add address-pool="management dhcp-pool" conflict-detection=no interface=MGMNT name=Management
add address-pool=iot-dhcp-pool conflict-detection=no interface=IoT lease-time=12h name=IoT
add address-pool=kubernetes-dev-dhcp-pool conflict-detection=no interface=KubeDev lease-time=1d name=KubeDev
add address-pool=kubernetes-prod-dhcp-pool conflict-detection=no interface=KubeProd lease-time=1d name=KubeProd
add address-pool=lan-dhcp-pool conflict-detection=no interface=MainLAN lease-time=6h name=LAN
/ipv6 pool
add name=KubeProdULA prefix=fd9d:7a72:44eb:c::/64 prefix-length=64
/queue type
add cake-flowmode=dual-srchost cake-nat=yes kind=cake name=cake-upload
add cake-flowmode=dual-dsthost cake-nat=yes kind=cake name=cake-download
/queue tree
add bucket-size=0.001 max-limit=600M name=download packet-mark=no-mark parent=MainLAN queue=cake-download
add bucket-size=0.001 max-limit=600M name=download-kube packet-mark=no-mark parent=KubeProd queue=cake-download
add bucket-size=0.001 max-limit=100M name=upload packet-mark=no-mark parent=ether1 queue=cake-upload
/system logging action
set 0 memory-lines=100
/container config
set registry-url=https://registry-1.docker.io tmpdir=containers/tmp
/disk settings
set auto-media-interface=*B auto-media-sharing=yes auto-smb-sharing=yes
/ip smb
set enabled=no
add bridge=*B comment=defconf interface=ether8
add bridge=bridge interface=fiber-trunk pvid=99
add bridge=bridge interface=ether4 pvid=10
add bridge=bridge interface=ether5 pvid=10
add bridge=bridge interface=ether3 pvid=110
/ipv6 settings
set accept-router-advertisements=yes
/interface bridge vlan
add bridge=bridge tagged=bridge,fiber-trunk vlan-ids=110
add bridge=bridge tagged=bridge,fiber-trunk vlan-ids=105
add bridge=bridge tagged=bridge,fiber-trunk untagged=ether8 vlan-ids=99
add bridge=bridge tagged=bridge,fiber-trunk vlan-ids=50
add comment=defconf disabled=yes interface=*B list=LAN
add interface=bridge list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=wan2 list=WAN
add interface=ether1 list=WAN
add interface=MainLAN list=LAN
add interface=KubeDev list=LAN
add interface=KubeProd list=LAN
add interface=IoT list=LAN
add interface=KubeDev list=VLANs
add interface=KubeProd list=VLANs
add interface=IoT list=VLANs
add interface=MainLAN list=VLANs
add interface=MGMNT list=LAN
add address=172.19.0.1/24 interface=bridge network=172.19.0.0
add address=192.168.99.1/24 interface=MGMNT network=192.168.99.0
add address=10.0.50.1/24 interface=IoT network=10.0.50.0
add address=10.0.110.1/24 interface=KubeDev network=10.0.110.0
add address=10.0.105.1/24 interface=KubeProd network=10.0.105.0
add address=192.168.2.1/24 interface=MainLAN network=192.168.2.0
add address=10.13.38.4/24 interface=backdoor network=10.13.38.0
/ip cloud
set ddns-enabled=yes
/ip cloud advanced
set use-local-address=yes
/ip dhcp-client
add default-route-distance=25 default-route-tables=main interface=ether1 use-peer-dns=no
add default-route-distance=254 disabled=yes interface=wan2
add address=10.0.50.0/24 comment="IoT DHCP Network" dns-server=10.0.50.1 domain=iot.<snip>.fi gateway=10.0.50.1
add address=10.0.105.0/24 comment="Kubernetes Production DHCP Network" dns-server=10.0.105.1 domain=kubeprod.<snip>.fi gateway=10.0.105.1
add address=10.0.110.0/24 comment="Kubernetes Development DHCP Network" dns-server=10.0.110.1 domain=kubedev.<snip>.fi gateway=10.0.110.1
add address=192.168.2.0/24 comment="LAN DHCP Network" dns-server=192.168.2.1 gateway=192.168.2.1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
add address=192.168.99.0/24 comment="Management DHCP Network" dns-server=192.168.99.1 gateway=192.168.99.1
set allow-remote-requests=yes mdns-repeat-ifaces=IoT,MainLAN servers=2a07:a8c0::<snip>,2a07:a8c1::<snip>>,45.90.28.251,45.90.30.251
/ip firewall address-list
add address=10.0.0.0/24 list=backdoor-addr-v4
add address=172.17.50.0/24 list=backdoor-addr-v4
add address=10.0.1.0/24 list=backdoor-addr-v4
add address=172.17.51.0/24 list=backdoor-addr-v4
add address=<snip>.sn.mynetname.net list=WANs
add address=192.168.2.0/24 list=LANs
add address=10.0.105.0/24 list=LANs
add address=10.0.110.0/24 list=LANs
add address=10.0.50.0/24 list=IoT
add address=10.0.199.0/24 list=backdoor-addr-v4
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=input dst-address-list=WANs dst-port=51821 protocol=udp
add action=accept chain=input comment="Allow multicast DNS" dst-address=224.0.0.251 dst-port=5353 in-interface-list=VLANs protocol=tcp
add action=drop chain=input disabled=yes dst-port=8291 in-interface-list=WAN protocol=tcp
add action=drop chain=input comment="Drop port 53 access from WAN" disabled=yes dst-port=53 in-interface-list=WAN protocol=tcp
add action=drop chain=input comment="Block NTP from WAN" disabled=yes dst-port=123 in-interface-list=WAN protocol=udp
add action=accept chain=input dst-port=4443 in-interface-list=VLANs protocol=tcp src-address=10.0.105.0/24
add action=accept chain=input dst-port=161 protocol=udp src-address=192.168.99.0/24
add action=accept chain=forward comment="Allow MQTT from IoT network to Kubernetes SVCs" dst-address=10.96.69.0/24 dst-port=1883 log-prefix=mqtt protocol=tcp src-address=10.0.50.0/24
add action=accept chain=forward comment="Allow homekit bridge" dst-address-list=IoT src-address=192.168.2.0/24
add action=accept chain=forward comment="Allow IoT to LAN" dst-address=192.168.2.0/24 src-address-list=IoT
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=accept chain=forward comment="Invalid packets to VLANs" connection-state=invalid in-interface-list=LAN log-prefix=INVALID: out-interface-list=VLANs
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall mangle
add action=mark-connection chain=prerouting comment="Mark connections for hairpin NAT" disabled=yes dst-address-list=WANs new-connection-mark="Hairpin NAT" src-address-list=LANs
add action=change-mss chain=forward new-mss=clamp-to-pmtu protocol=tcp tcp-flags=syn
add action=masquerade chain=srcnat comment="Hairpin NAT" connection-mark="Hairpin NAT" disabled=yes
add action=masquerade chain=srcnat comment="NAT Containers Traffic" out-interface=bridge src-address=172.19.0.0/24
add action=masquerade chain=srcnat dst-address-list=backdoor-addr-v4 log=yes out-interface=backdoor
add action=dst-nat chain=dstnat comment="Port-Forward to Kubernetes cluster external ingress" dst-address-list=WANs dst-port=80 protocol=tcp to-addresses=10.96.69.80 to-ports=80
add action=dst-nat chain=dstnat comment="Port-Forward to Kubernetes cluster external ingress" dst-address-list=WANs dst-port=443 protocol=tcp to-addresses=10.96.69.80 to-ports=443
add action=dst-nat chain=dstnat comment=Bittorrent dst-port=57427 in-interface-list=WAN protocol=tcp to-addresses=10.41.69.202 to-ports=57427
add action=dst-nat chain=dstnat comment="Port-forward for Factorio" dst-address-list=WANs dst-port=31497 in-interface-list=WAN log=yes protocol=udp to-addresses=10.96.69.200 to-ports=31497
add distance=1 dst-address=172.17.51.0/24 gateway=backdoor routing-table=main scope=30 target-scope=10
add distance=1 dst-address=10.0.0.0/24 gateway=backdoor routing-table=main scope=30 target-scope=10
add distance=1 dst-address=10.0.1.0/24 gateway=backdoor routing-table=main scope=30 target-scope=10
add distance=1 dst-address=172.17.50.0/24 gateway=backdoor routing-table=main scope=30 target-scope=10
add dst-address=192.168.100.0/24 gateway=ether1
add disabled=no distance=1 dst-address=10.0.199.0/24 gateway=backdoor routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ipv6 route
add disabled=no distance=1 dst-address=::/0 gateway=fe80::213:2%ether1 routing-table=main suppress-hw-offload=no
add dst-address=2001:67c:1be8:2::/64 gateway=backdoor
/ipv6 address
add address=fd9d:7a72:44eb:e::1 interface=IoT
add address=fd9d:7a72:44eb:d::1 interface=KubeDev
add address=fd9d:7a72:44eb:c::1 interface=KubeProd
add address=fd9d:7a72:44eb:a::1 interface=MainLAN
add from-pool=delegated-wan interface=MainLAN
add address=::f61e:57ff:fe51:88f4 eui-64=yes from-pool=delegated-wan interface=KubeDev
add address=::1 advertise=no from-pool=delegated-wan interface=KubeProd
/ipv6 dhcp-client
add interface=ether1 pool-name=delegated-wan rapid-commit=no request=address,prefix use-interface-duid=yes use-peer-dns=no
/ipv6 dhcp-server
add address-pool=KubeProdULA interface=KubeProd name=k8s-prod prefix-pool=KubeProdULA
/ipv6 firewall address-list
add address=2001:67c:1be8:2::/64 list=backdoor-addr-v6
add address=fd9d:7a72:44eb:a::/64 list=k8s_ula
add address=fd9d:7a72:44eb:c::/64 list=k8s_ula
add address=fc00::/7 comment="ULA range" list=bad_ipv6
/ipv6 firewall filter
add action=accept chain=input dst-port=179 in-interface-list=VLANs protocol=tcp
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!VLANs
add action=passthrough chain=input disabled=yes dst-port=443 in-interface-list=WAN protocol=tcp
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" log=yes out-interface-list=!WAN src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6 out-interface-list=!WAN
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=5" disabled=yes hop-limit=equal:5 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=accept chain=forward dst-address=2001:<snip>:45a:213d::4443/128 dst-port=80 in-interface-list=WAN protocol=tcp
add action=accept chain=forward dst-address=2001:<snip>:45a:213d::4443/128 dst-port=443 in-interface-list=WAN log=yes protocol=tcp
add action=drop chain=forward comment="Drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=output comment="Allow outgoing BGP traffic" dst-port=179 protocol=tcp
/ipv6 firewall mangle
/ipv6 firewall nat
add action=dst-nat chain=dstnat dst-port=443 in-interface-list=WAN protocol=tcp to-address=2001:<snip>:45a:213d::4443/128 to-ports=443
add action=dst-nat chain=dstnat dst-port=80 in-interface-list=WAN protocol=tcp to-address=2001:<snip>:45a:213d::4443/128 to-ports=80
add action=masquerade chain=srcnat comment="K8S ULA nat out" log=yes log-prefix="k8s: " out-interface=ether1 src-address-list=k8s_ula
add action=dst-nat chain=dstnat comment=Factorio dst-port=31497 in-interface-list=WAN protocol=udp to-address=fded:687e:c3bf::200/128 to-ports=31497
add action=masquerade chain=srcnat dst-address=2001:67c:1be8:2::/64 out-interface=backdoor to-address=2001:<snip>:1be8:2::/64
/ipv6 nd
set [ find default=yes ] disabled=yes dns=:: hop-limit=64
add advertise-mac-address=no dns=fd9d:7a72:44eb:c::1 hop-limit=3 interface=KubeProd managed-address-configuration=yes ra-interval=10s-1m40s ra-preference=high
add advertise-mac-address=no disabled=yes dns=fd9d:7a72:44eb:e::1 hop-limit=64 interface=IoT managed-address-configuration=yes
add advertise-mac-address=no dns=fd9d:7a72:44eb:a::1 hop-limit=64 interface=MainLAN ra-interval=30s-1m40s
add advertise-mac-address=no dns=fd9d:7a72:44eb:d::1 hop-limit=64 interface=KubeDev managed-address-configuration=yes ra-interval=30s-1m40s
