LED COMMAND...
HI,
I can’t found LED command on scripting list… I use RB532 board. Any idea?
Regards
Xandor
There is ‘blink’,
and you may set ‘blink duration=10’.
HI,
But for enable led1, led2, led3, etc…
Regards
Xandor
You can use Ether1,Ether2, Ether3.
‘interface ethernet blink ether1’.
HI,
I need to enable led onboard to RB532, in your script exampèle I have found it:
[admin@MikroTik] > :
beep execute global list pick time toip typeof
delay find if local put toarray tonum while
do for led log resolve tobool tostr
environment foreach len nothing set toid totime
[admin@MikroTik] >
If you see led command is present, instead isn’t present into my RB532.
I have to add any new package on RB532 for obtain it?
Regards
HI again,
I need to use wireless interfaces and not ethernet.
In wireless blink command isn’t available.
I need a script for associate radio signal level to inside led on RB532.
Idea can be:
No signal:
/sys scheduler set 0 on-event=“/blink duration=100ms” interval=1s
-95 to -90
/sys scheduler set 0 on-event=“/blink duration=250ms” interval=1s
-90 to -85
/sys scheduler set 0 on-event=“/blink duration=400ms” interval=1s
-85 to -80
/sys scheduler set 0 on-event=“/blink duration=500ms” interval=1s
-80 to -75
/sys scheduler set 0 on-event=“/blink duration=750ms” interval=1s
-75 or less:
/sys scheduler set 0 on-event=“/blink duration=1s” interval=1s
But I need support for connect this script to radio signal level of wireless interface
Regards
