When plugged with PoE adapter (with its power adapter) does the “power” led light if the Eth cable is disconnected?
Does the led light if I plug the Eth cable (Cat6a) on PoE adapter but not in the Mikrotik device?
Do I have to use only Cat6A cable?
How do I check if the device is powered?
yes
yes (i dont see the difference with your first question)
No
Power led, beeper, computer etc…
