I have two identical CRS326-24G-2S+ and I did reset the configuration to default. On one switch the interface order shows up correctly, on the other the following LEDs are incorrect:
/system/leds> print
Flags: * - DEFAULT
Columns: TYPE, INTERFACE, LEDS
# TYPE INTERFACE LEDS
0 * interface-activity ether19 ether1-led
1 * interface-activity ether24 ether2-led
I can change the LEDs manually, but I wonder why they are not set correctly by default. The firware is 7.22.2 on both switches.
