Hi Guys
Can we setup LEDS for modem signal strength (signal strength onn 3G modem) i-e -60 to -70 LED1, -71 to -81 LED2 and so on
Hi Guys
you can set up LEDs in menu “/system leds” and specify type “modem-signal”, then configure threshold:
http://wiki.mikrotik.com/wiki/Manual:System/LEDS#Configuration_Properties
samir494, question was about 3G modems
thanks,
i send code for ref. ,
actual interface & type is depend on user to set as his require
Thanks Normis and Samir494 for your responses but it doesn’t work as expected
I have set LEDs as described below
LEDS Threshold
LED1 -60
LED2 -70
LED3 -80
LED4 -90
LED5 -100
At the moment, 3G signal strength on my device is -93 and LEDS from 1-4 are ON. If I use just one LED (e-g LED1) with Threshold -60, it will be ON even when signal strength is below -90.These LEDS needs to work other way around
Now I’m not able to put some range in threshold (e-g <=70 or -70 to 90 for LEDs) for modem signal strength.
Can you please provide some assistance on this please.
I have the same issue as m2mconnectivity.
Is it possible to invert the LED’s?
Currently RouterOS modem LED setting supports only one LED. We could check if we could add invert option for the LED.
