There is a cAP is controlled by CAPsMAN:
/system leds add leds=led4 type=ap-cap
Led “led4” is not lit!
Why?
Thanks for the reply!
Why?
The answer of support:
“disable and enable the CAP mode on the AP and it should start to use that LED”
Thank you! It works!
