LEDs on cAP-2n board
Is it possible to disable the LEDs the cAP-2n ceiling access point?
I know they aren’t particularly bright, but for some rooms (such as bedrooms) it would be preferable if they could be turned off.
yes, all of the leds in this device can be turned off, including power
I cannot figure out how to do this in WinBox (v3.0beta3) on cAP-2n v6.20.
In ‘System > LEDs’ there are no LEDs listed. I’ve added all six (1 to 5, and ‘user-led’ ) and tried set them to type ‘ap cap’ - and tried with them enabled and disabled.
Can you share the commands needed to disable them?
Still haven’t been able to figure this out :frowning:
On UniFi AP kit its a simple change in system settings.
Can anyone (especially MikroTik spport!) provide the commands?
I would like to know how to disable the Power LED as well. I was able to disable every LED except the Power.
you can do it with this command:
/system leds add led=all-leds type=off
