Less detail on Tx/Rx Rate on hAP ax lite LTE
On the registration tab of a hAP ax lite LTE, speed is simply shown as Mbps:
But on an older hAP ac lite, you get to see channel width and number of streams:
Why is there less information on the newer device?
because of the use of different hardware that devices you are comparing use different wireless software packages, and consequently have somewhat different functionalities and provide different information
So the new WiFi driver has less features that the old Wireless driver :frowning:
Yes. Get used to it.
Don’t want to get used to it :confused: For diagnosis purposes of Wi-Fi strength, this was a very handy feature. Also quick way to determine the radio status of a client device. It was one of those USPs of Router OS…
Want it or not, there are very slim chances to get it changed.
We’ve been complaining about missing features (including spectral scans, connection details, lack of nv2 and/or nstreme) ever since wifiwave2 existed … and these features are still missing. To be fair, some were implemented (at least in wifi-qcom), such as VLAN tagging. But I’d say that yield is poor.
it has some benefits even for “old” specific 802.11ac devices which support the new software package, but keep in mind that hAP ac lite is not one of them
WiFi-Benefits
  • WPA3 authentication and OWE (opportunistic wireless encryption)
  • 802.11w standard management frame protection
  • 802.11r/k/v
  • MU-MIMO and beamforming
  • 400Mb/s maximum data rate in the 2.4GHz band for IPQ4019 interfaces
These benefits apply both to the wifi-qcom and wifi-qcom-ac packages.
https://help.mikrotik.com/docs/spaces/ROS/pages/224559120/WiFi#WiFi-Benefits
Lost features
The following notable features are lost when running 802.11ac products with drivers that are compatible with the ‘wifi’ management interface:
  • Nstreme and Nv2 wireless protocols
  • VLAN configuration in the wireless settings (Per-interface VLANs can be configured in bridge settings)
  • Compatibility with station-bridging as implemented in the ‘wireless’ package, station-bridge only works between the same type of drivers. Wifi to Wifi, and Wireless to Wireless.
https://help.mikrotik.com/docs/spaces/ROS/pages/224559120/WiFi#WiFi-Lostfeatures
