Less than 10% of IPv4 Addresses Remain Unallocated
Saw this from ARIN today…
http://www.nro.net/media/less-than-10-percent-ipv4-addresses-remain-unallocated.html
We really need IPv6 PPP support in Mikrotik!!!
Yes we do!
RFC2472
http://www.faqs.org/rfcs/rfc2472.html
Linux PPPv6
http://ipv6int.net/systems/linux-ipv6.html#pppv6
I heard the intent with IPv6 is to assign each user at least one subnet and likely more. So each device in there home will have a public v6 IP. Does the PPPoE protocol support handshaking and telling the client what size subnet it is being given?
[arin-discuss] IPv6 End User Assignments
http://lists.arin.net/pipermail/arin-discuss/2009-May/001189.html
PPP doesnt need to support it. PPP is just a point to point connection and you create a route on the CPE and the border router.
PPPoE ‘needs’ to support it…
Why? It functions the same way as any other encapsulated ppp connection.
PPPOE connection 10.0.0.1 on server to 10.0.0.2 on client. Client has IP range 1.2.3.0/28. Server has a route (can be supplied by radius) to route 1.2.3.0/28 via 10.0.0.2. CPE default gateway is 10.0.0.1. CPE lan IP address is 1.2.3.1/28, hosts behind client cpe are 1.2.3.2/28 thru 1.2.3.14/28 with default gateway 1.2.3.1.
Works like a champ.
Know anyone that needs a “super B” range…
Works like a champ.
So have you made this work? On over a hundred PPPoE clients as well?
I see this in old change log.
“What’s new in 3.18:
*) do not send IPv6 packets over PPTP, L2TP or PPPoE - could confuse some
servers or clients;”
The thread got off track. Ive never tried it on IPv6, but I do it on IPv4 w/ OpenVPN and L2TP.
Yes, IPv6 needs to be supported. But I dont think the PPP protocol needs to be rewritten to send subnet information across the link. There are other standard ways to handle that.
