Hi, I’m trying to get OSPF up and running
and would like to ask if I can somehow set it to ignore the default route and leave it as is.
Everything is between 2 routers, both connected to the internet, one has a DHCP address and this other one has a dynamic address via PPPoE. The OpenVPN server is running on this one. The first one is a client so I can easily set the route on the interface. For this server also, but after a connection failure the route disappears. Hence OSPF.
As you can see in the green entry, it works.
Unfortunately, OSPF also tries to create a new default route 2) via OpenVPN, which cuts a branch underneath itself, since everything is connected to the Internet via 1) Cetin PPPoE. So it gets into a cycle and keeps repeating.
I’d use Wireguard, but it only runs between 2 other routers in my current RouterOS v7.5 version, and I can’t add a third.
Is there a way to set it to leave the default route albeit dynamic as is?
