Well at this one install i’ve ONLY ordered and installed NMP-8602s…did it all myself… one of my 532s however shows a atheros AR5213 whereas all the other are Atheros AR5413 as NMP-8602s are.
The questoned radio works perfectly i just am curious as to what is…I’m guessing that whom ever i ordered them from accidently gave me 1 wrong radio. sooo:
(btw this router is 500 miles away so i cant just open the box and see)
RB532 is running 2.9.23..no issues
I dont think its a SR2 since my sr2 here does NOT give me the “Advanced Status” tab in Winbox as this card does.
It shows TX power of 26dBm…it only does 2.4gHz… allows me to choose:
2.4g - b
b/g
G only
g turbo mode
2ghz 5mhz ch
2ghz 10 Mhz ch
Mac addy vend is: 00:15:6D = Ubiquiti Networks
i have the status tab, the advanced status tab and compression tab..
any guesses or other clues i can gather?
i only ask bc this is such a dumb link, i watned to have a cheap crap card in there…ie NMP-8602… what ever this jewel card is, it needs to be put somewhere where it will be appreciated and used.
tks
