Hello guys, I just bougth a level 4 license and just wanna know if there is a limit with ppp user and hotspot, because I can create more than 200 users the question is how does it work the limit?
regards
regards
Just check http://wiki.mikrotik.com/wiki/Manual:License
It says max 200 PPP tunnel not user. you can create a lot but 200 PPP tunnel at a time
ok thanks
