LHG 5
Does the LGH 5 support only 5Ghz signals or can it also support 2.4?
https://routerboard.com/RBLHG-5nD
The LHG5? It supports only 5ghz
If it would support 2.4 GHz, it would be called LHG 2. Dual band would be like LHG 52.
Btw, don’t expect an outdoor AP with a high performance panel antenna to be dual band.
I just ordered two of LHG 5’s :slight_smile: 3.5km distance, should work nicely :slight_smile:
Please report back about your results :slight_smile:
2xLHG5 , 10km, 120mbps
Thank you InoX!
Time to buy some :slight_smile:
I’ve installed ~15 LHG in the same spots where AirGrids 23/27. All LHG have 10-30 dbi better signal than AirGrids.
3.5km, two LHG5’s 135 mbps :slight_smile: , working perfectly, what a great cheap antenna+everything else you need :slight_smile:
Thank you, I really needed some real life results. Great.
We have some of them in our hamnet and they work well, but we are not after those high speeds.
(10 MHz bandwidth and plain 802.11)
