LHG 5AC Latency Problem
I have a problem with this antenna, my brother gives me 200 mbps internet via wifi, previously I used a third-party antenna AC and I only got 150 of the 200 mbps, I installed the LHG 5AC and it reached 200 mbps but every 5 minutes the Latency increased horribly for 5 seconds this prevents me from playing online, this did not happen with the previous antenna I had, what could be the problem ?.
I am facing to the same problem. Have you found any solution yet?
Most likely the issue is caused due to “station-roaming” being enabled on the station side. Please try disabling it and see if the issue still returns.
We’ve set it as “disabled” by default now. It does not adjust anyone’s configuration automatically in case someone intentionally needs it.
As described in the wiki, it is useful only if there are multiple AP’s that station can connect to.
The reason why it can cause latency spikes can be found in the wiki: https://wiki.mikrotik.com/wiki/Manual:Interface/Wireless#Station-Roaming
Sorry for the inconvenience caused.
@Reinis After disabling “station-roaming” the problem is solved. Thanks a lot!
