LHG LTE 6 KIT router was rebooted
Hi sorry for my english. I bought myself a LHG LTE 6 KIT. + Lightning protection RBGESP began to reboot itself after one day of operation. The log file shows that the router has been rebooted with an error without a proper shutdown. This is critical for me. How can this problem be solved. Installed ROS 6.46.8 (Long-term)
First, you should start monitor that and set a notification to e-mail after reboot.
About information in log, it’s general and you can change action in logging to disk , to prevent last log to vanish. You can setup the syslog too.
Check if new file the autosupout.rif exist, this can be done by watchdog feature.
How long is ethernet cable ? You use switch with poe or injector kit ?
Hello! Thanks for attention.
Notifications are on but they don’t come, ftp cat5e cable is 20m, i am using RBPOE and i have lhg connected to asus router and when computer is connected to lhg router it restarts with error, router was restarted with error without proper shutdown. Sorry for my English
This is happend one time or many time and still it’s reboot like every 1h or every 1day… how oftern it’s
You check the Files about autosupout.rif ?
You check System\Watchdog, add e-mail, enable Automatic, enable Timer and watch address like 8.8.8.8
You can set own logging with action to disk to save logs at nand and read them after reboot.
