Hi
Bought LHG LTE kit to use 4g in rural location. I have managed to upgrade to Router OS 6.47.2. And i can see connection to vodafone, but cannot access internet. I have tried default reset… Any help would be great thanks
Paste your config using hide sensitive.
Regards.
Do a first installation with QuickSet feature ! When you learn that router then you will do that stuff manual.
But at start just use all checkbox, special NAT one who probably is missing in your config !
