Hey guys I am wondering if anyone else has seen the issue of a tremendous speed drop after upgrading from ROS 6.42.5 to ROS 6.43.8 on the RBLHGR R11e-LTE-US Kit.
With OS 6.42.5 speeds were consistently at 12 Mbps down and 2 up. After upgrading to 6.43.8 speeds run around 2.5 Mbps down and 1 Mbps up.
This is straight out of the box just adding the Correct APN and doing updates. On Band 4.
I am not seeing anything in the update notes that would indicate this being affected. Or am I missing something?
*) lte - disallow setting LTE interface as passthrough target;
*) lte - fixed DHCP IP acquire (introduced in v6.43.7);
*) lte - fixed passthrough functionality when interface is removed;
*) lte - increased reported “rsrq” precision;
*) lte - reset USB when non-default slot is used;
