Hi, I would like to upgrade the R11e firmware in the LHG but cannot because the simm card is on a private APN with no internet access. The LAN interface does however have internet access but the R11e has to upgrade via the LTE connection.
Is it possible to get a firmware version from Mikrotik to upgrade by uploading as opposed to updating via LTE connection.
I upgrade firmware modem via LAN side too but the lte1 must have running status.
Every modem r11e-* have got other behaviour - check prev. post (copy of documentation).
Thanks for the reply. I do upgrade OS and routeboard via LAN side. When I run the LTE firmware update though, it does not want to update through the LAN interface. The LTE interface does have the running flag but I can’t figure out how to get the update through the LAN interface. Is there a specific FQDN that I have to route to through the LAN interface? An example of how to get the modem to update via LAN is exactly what I am looking for.
only support@mikrotik.com can give you answer. I not debug this process. I think that LAN upgrade is possible only for 4G and LTE6 via LAN side (because they can upgrade via file) but maybe this file must be downloaded only via lte1 interface - if this is a case then you must provide other sim to do so.
You can write e-mail to support@mikrotik.com and ask them about update about your modem.
PS. In title you write LHG LTE but you not specify what modem you have and that way I answer you about all modems in my answers.
