LHG LTE18 KIT via haP ac3 router, no internet detected, still it is working – settings advice is sought
Hello MikroTik World
Preamble:
I am new to the brand. For our home internet, we needed a powerful antenna as we live in a remote area, literally at the very end of the copper line. Installed this combination 6months ago, it has been working fine, super-fast but relatively often it kept dropping android devices so I started looking into it. I updated the firmware on both but in the attempt for resolving the issue I managed to screw up the whole lot. (http://forum.mikrotik.com/t/lhg-lte18-kit-not-visible-on-network-but-internet-is-detected-how-to-reset-it-from-remote/165609/1)
Issue:
Now I am back to square one, with a twist.
  1. When I am directly connecting to the antenna, the internet is fine. (Via MikroTik app, winbox, USB to Ethernet adapter for the phone, cable for the laptop)
  2. When the antenna is connected to the hap ac3 via ethernet port 5 (PoE out) the “internet detect” can’t find internet and all android devices show no internet. However, once I logged in to the antenna via winbox through hap ac3 from my laptop -and didn’t do any changes- suddenly all android devices started to have internet. The internet detect still can’t see internet in winbox nor in the MikroTik app.
  3. If the antenna is connected to the hap ac3 via ethernet port 1 (which is labelled as Internet) via a PoE injector data out, then I have no internet at all.
In case 2. & 3. I used the hap’s quick setup, everything left as automatic. Whenever I started changing things, the internet is just not available.
Question:
Could someone please point out my beginner’s mistake from the “myconfig”-s below? I have spent weeks now reading the forum and testing settings. I would like to learn from it.
LHG LTE18 KIT config:
# apr/12/2023 09:43:00 by RouterOS 7.8
# software id = XXXX-XXXX
# model = LHGGM
# serial number = XXXXXXXXXXX
/interface lte
set [ find default-name=lte1 ] allow-roaming=no band=""
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=default-dhcp ranges=192.168.188.10-192.168.188.254
add address-pool=default-dhcp interface=ether1 name=defconf
/port
set 0 name=serial0
add comment=defconf interface=ether1 list=LAN
add comment=defconf interface=lte1 list=WAN
add address=192.168.188.1/24 comment=defconf interface=ether1 network=\
    192.168.188.0
add address=192.168.188.0/24 comment=defconf dns-server=192.168.188.1 \
    gateway=192.168.188.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.188.1 comment=defconf name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/London
/tool mac-server
/tool mac-server mac-winbox
Hap ac3 config:
# apr/12/2023 11:07:03 by RouterOS 7.7
# software id = xxxx-xxxx
# model = RBD53iG-5HacD2HnD
# serial number = xxxxxxxxxxx
add admin-mac=xx:xx:xx:xx:xx:xx auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country="united kingdom" disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge ssid="MikroTik 2.4" wireless-protocol=\
    802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX country="united kingdom" disabled=no distance=indoors \
    frequency=auto installation=indoor mode=ap-bridge ssid="MikroTik 5" \
    wireless-protocol=802.11
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
set discover-interface-list=all
/interface detect-internet
set detect-interface-list=all
add interface=ether1 list=WAN
add interface=wlan1 list=WAN
add interface=ether5 list=LAN
add interface=ether5 list=WAN
add interface=wlan1 list=LAN
/interface wireless access-list
add interface=LAN
    192.168.88.0
/ip dhcp-client
    192.168.88.1
/ip dns static
    invalid
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
    invalid
    icmpv6
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
/tool mac-server
Thank you for your time.
