I have the lhg lte6 kit, have logged into the quick setup and SIM is inserted, it shows as having the EE card inserted and signal is showing. But can’t figure out how you connect to the internet. What settings do I need to change.
After provide APN it’s should connect, show you a IP at lte1 interface in WinBox > IP > Address.
You should see route to internet via lte1 in WinBox > IP > Route
Check if this SIM card have active Internet, you check proper APN. This should just work out-of-box.
