Hello everyone,
I’m here in the bosnian country side, near the lipacamp, trying to get some connexion through an lhg lte6 kit with a BH sim card, but it seems i could use some of your help ^^.
the sim is working as i could go in the internet with a phone and send a sms from the antena.
I archieve to update the firmware and i’m now running on 6.48.1 with the basic setup after reset :
The following default configuration has been installed on your router:
Welcome to RouterOS!
1) Set a strong router password in the System > Users menu
2) Upgrade the software in the System > Packages menu
3) Enable firewall on untrusted networks
CPE RouterMode:
* wireless interface connected to providers network (WAN port);
* WAN port is protected by firewall and enabled DHCP client
LAN Configuration:
IP address 192.168.88.1/24 is set on ether1 (LAN port)
DHCP Server: enabled;
DNS: enabled;
WAN (gateway) Configuration:
gateway: lte1 ;
ip4 firewall: enabled;
NAT: enabled;
I think i should be able to reach internet with this setup but not. (ping to 8.8.8.8 return no route to host error)
I see that the internet adress is 0.0.0.0, that could be the issue (maybe BH mobile doesnt give me an ip)
Many thanks for your time =D
jund
