LHG R 4G kit "cell-monitor" command missing
Good day,
Few days ago purchased MikroTik LHG 4G kit. After some tests I figured that local gsm operator has internet stability problems on closest to me tower, because speed sometimes go extremely down. I desired try connect to another, and try force modem to choose it. Referring Mikrotik wiki:
https://wiki.mikrotik.com/wiki/Manual:Interface/LTE
I should use cell-monitor to detect other stations nearby. But seems this command is missing, what I’m missing?
RouterOS 6.43.8 (stable)
pin-status: no password required
functionality: full
registration-status: registered
manufacturer: MikroTik
model: R11e-4G
revision: R11e-4G_V005
current-operator: 247,02
lac: 560
current-cellid: 51227169
enb-id: 200106
sector-id: 33
phy-cellid: 67
access-technology: Evolved 3G (LTE)
session-uptime: 1d19h52m16s
imei: 359147090084712
imsi: 247021002777304
earfcn: 1574 (band 3, bandwidth 20Mhz)
rssi: -30dBm
rsrp: -52dBm
rsrq: -14dB
sinr: 13dB
cqi: 11
p.s. lte scan command also not working (after 3 minutes of scanning zero results).
This command is available since 6.44beta14. Switch to testing channel and upgrade if you want to use it now, or wait until 6.44 is considered stable.
https://mikrotik.com/download/changelogs/testing-release-tree
What’s new in 6.44beta14 (2018-Oct-01 12:01):
Changes in this release:
*) lte - added “cell-monitor” command for R11e-LTE international modem (CLI only);
Still missing - am running 6.46.3 - up to date, and lates firmware. - and getting this error message
pin-status: ok
functionality: full
model: R11e-4G
revision: R11e-4G_V007
[admin@MikroTik] > interface lte cell-monitor lte1
failure: cell-monitor not supported!
[admin@MikroTik] > interface lte cell-monitor 0 duration=10s
[admin@MikroTik] >
Anyone know why it doesn’t work?
Same issue, anyone figure this out.
As you can see this feature is for R11e-LTE not for R11e-4G
With latest LTE firmware on described interface model and ROS release is working perfectly.
PD: Updated firmware to v018 and works well.
Regards.
