Hi all:
I’ve been really struggling to get an LHG-R up and going with Visible (Verizon) cell service to feed a remote customer. They aren’t looking for much; its a business that needs some remote monitoring and ability to run VoIP and some websites. In any case, there’s a cell tower that is line of site from up on their structure. But I haven’t even made it that far…
Microtik doesn’t offer any cell modems that include B13, which is where Verizon/Visible service is at. So I found the Quectel EC25-AF and acquired that. When I get it all installed and configured in the LHG-R (with latest firmware from Quectel and running RouterOS 7.7), it all comes up, but the max speed I can get is 5Mbps up and down. If I take the sim and EC25-AF out of the microtik device and install it in a USB mini-PCIe adapter, windows comes right up on cell data and gives me 60x20. During the speedtests on the Quectel EC25-AF, It does briefly surge above 5Mbps, then quickly comes back down.
I’ve only come up with two ideas to explain this:
- the interface or data pathways on the microtik board are only capable of 5Mbps; the initial surge is filling some buffer, but sustained data throughput is maxing some path out at 5Mbps.
- For some reason, the LHG-R is causing the data to appear to the cell provider as “hotspot” data rather than “native” data – there is a 5Mbps unlimited hotspot on this plan.
To test #2, I had a different Microtik device (LtAP) with a different Quectel card (RM500Q-GL). I put the SAME sim into that router, and achieved 40x15Mbps (and I think that was antenna differences). The LtAP started out with a factory reset and the default Quickset script applied, just like the LHG-R, which makes me suspect #2 isn’t happening…
I tried looking on Microtik’s website for a block diagram of how the different interfaces are attached to what on the micrporocessor like I can find for the LtAP, but no such diagram or technical information appears to be available for the LHG-R.
Can anyone shed some light on the cause of this slowdown and if there is any fix for it?
Thanks!
–Jim
